Starting to get into 3D modeling...
Oowoon
With the help of a friend, I've took up modeling 3D models in 3DS max.
The first (Noteworthy of posting) model is the Hero's Shield from Majora's Mask.
What do you guys think? It still needs work, of course. I need to add a bending modifier to give it more of a shield-like appearance, and theres a few creases that I need to work out. But overall, I think I did a fairly good job.
EDIT: Picture updated to refined shield,
A week from the original model, I bring you the textured version!
It was decided to replace the bottom part with the goron ruby instead, I'll put it in skyrim when I get the chance.
Great job on that if that is just for practice and to get better, if its something you plan to import ingame, its definitely too high poly. But other then that, great job on it so far and keep at it. :3
If anything, I'd intend to import it into Skyrim.
Also, I'd bake the details in this model into a normal map.
That is one sexy beast. I think though if you're going to hide the Goron Ruby in there that you should hide the other two gems as well. Maybe put the Zora Sapphire at the top grey metal piece inside the shield and the Kokiri Emerald in the red part in the middle instead of that white thing. I dunno, that would just make the ruby make sense I think.
Sent from the Netherworld.
