Help With Zelda MM Decompressed rom
Ghost
8 answers to this question
If the Expansion Pak was disabled, the game wouldn't even start as far as I remember, and instead only spit out an error message. That said, there's other options than the Expansion Pak that might be worth double-checking - I'm assuming you use Project64, if that's the case, after starting the ROM open the emulator's "Options" menu, go to "Settings", then "ROM Settings" and make sure your settings look like this:
Those are the settings with which Majora's Mask (compressed, European, but shouldn't matter) runs for me.
