[Zelda Debug, Map Modification]: How edit the FOG?
â–²ChriisTiianâ–²
5 answers to this question
This should help you, scroll down to where the environment editor section is regarding debugging controls. As for making your edits permanent, I can't remember if fog is an actor, or controlled by the map or scene header, or none of the above. spinout's wiki can probably point you in the right direction, though.
Hi.
Fog can be a actor, but this can't be added because can crash the room.
And about of edit the scene header, how i can do that?
Scene controlled.
