â–²ChriisTiianâ–² Posted April 24, 2012 Share Posted April 24, 2012 Hi, can somebody explain how to edit the FOG of a place? If anyone knows how to do it or have any idea about this, i would greatly appreciate. Link to comment Share on other sites More sharing options...
0 Secant Posted April 24, 2012 Share Posted April 24, 2012 This should help you, scroll down to where the environment editor section is regarding debugging controls. As for making your edits permanent, I can't remember if fog is an actor, or controlled by the map or scene header, or none of the above. spinout's wiki can probably point you in the right direction, though. Link to comment Share on other sites More sharing options...
0 â–²ChriisTiianâ–² Posted April 24, 2012 Author Share Posted April 24, 2012 On 4/24/2012 at 3:09 AM, 'Naxylldritt' said: This should help you, scroll down to where the environment editor section is regarding debugging controls. As for making your edits permanent, I can't remember if fog is an actor, or controlled by the map or scene header, or none of the above. spinout's wiki can probably point you in the right direction, though. Hi. Fog can be a actor, but this can't be added because can crash the room. And about of edit the scene header, how i can do that? Link to comment Share on other sites More sharing options...
0 Zeth Ryder Posted April 24, 2012 Share Posted April 24, 2012 On 4/24/2012 at 3:09 AM, 'Naxylldritt' said: This should help you, scroll down to where the environment editor section is regarding debugging controls. As for making your edits permanent, I can't remember if fog is an actor, or controlled by the map or scene header, or none of the above. spinout's wiki can probably point you in the right direction, though. Scene controlled. Link to comment Share on other sites More sharing options...
0 spinout Posted April 24, 2012 Share Posted April 24, 2012 0x0F command in scene header. http://wiki.spinout182.com/w/Maps_and_Scenes#Environments_list Link to comment Share on other sites More sharing options...
0 â–²ChriisTiianâ–² Posted April 24, 2012 Author Share Posted April 24, 2012 (edited) EDIT: Fixed! :D :D Edited May 18, 2012 by â–²ChriisTiianâ–² Link to comment Share on other sites More sharing options...
â–²ChriisTiianâ–²
5 answers to this question
