How to add custom music to Zelda TP and SS
Jack Walker
Non sequenced music in TP uses the .ast format while all music in SS uses the .brstm format.
Twilight Princess:
Note: The file you want to convert must be in .wav format.
1. Download the conversion program here.
2. Place your .wav file in the same folder as the conversion program.
3. Click and drag your .wav onto the converter program (astsharp.exe). If the program crashes then import your .wav into a program such as Audiacity and export it.
4. Insert your converted song using a program such as Wii Scrubber.
An example of a successful conversion can be found
Skyward Sword:
2. Open up BCSM-GUI.exe.
3. Click "Add" then "Add to Quene" and specify the file you want to convert.
4. Press the "Convert to BRSTM" button.
5. Insert your converted song using a program such as Wii Scrubber.
Credits:
Kamimatt - AST Conversion Program (Originally obtained from here)
Dantarion/BionicSonic - BRSTM Conversion Program (Originally obtained from here)
