SoulofDeity Posted October 10, 2012 Share Posted October 10, 2012 I know, I followed it step by step and still didn´t work. Well, I just applied the patch to my rom and it works just fine (even without a CRC recalc), so it's not the patch. My settings: Graphics Plugin: Jabo's Direct3D8 1.7.0.53 Feb 9 2007 Audio Plugin: Jabo's DirectSound 1.7 [ROM SETTINGS] CPU Core Style: Recompiler Function lookup method: Physical Lookup Memory Size: 8MB Advance Block Linking: Default Default Save Type: Use First Used Save Type Counter Factor: 2 [+] Register Caching [+] Fixed Audio Timing [+] Custom self-mod method [+] Cache [+] Start Changed Link to comment Share on other sites More sharing options...
Secant Posted October 10, 2012 Share Posted October 10, 2012 That's odd, I tested out the Dark Link patch just the other day, and it works fine on PJ64 1.6. Best I can recommend is checking your ROM settings and possibly your graphics plugin settings; if you need an outline for what options work, this page should help. Link to comment Share on other sites More sharing options...
pkjoan Posted October 10, 2012 Share Posted October 10, 2012 Ok so this seems to be my problem, any idea? Link to comment Share on other sites More sharing options...
xdaniel Posted October 10, 2012 Share Posted October 10, 2012 Is your ROM byte-swapped? Meaning, if you open it in a hex editor, can you read "THE LEGEND OF ZELDA" near the top, or is the text scrambled like "HT EELEG(...)" or somesuch? Link to comment Share on other sites More sharing options...
pkjoan Posted October 10, 2012 Share Posted October 10, 2012 Is your ROM byte-swapped? Meaning, if you open it in a hex editor, can you read "THE LEGEND OF ZELDA" near the top, or is the text scrambled like "HT EELEG(...)" or somesuch? It says LEGEND OF ZELDA Link to comment Share on other sites More sharing options...
Conker Posted October 10, 2012 Share Posted October 10, 2012 All I can tell you, is it's a problem on your end. If even one other person can run it fun(me), you're doing something very wrong. Link to comment Share on other sites More sharing options...
pkjoan Posted October 10, 2012 Share Posted October 10, 2012 But that´s what I want to know. What am I doing wrong? Link to comment Share on other sites More sharing options...
Conker Posted October 10, 2012 Share Posted October 10, 2012 I honestly don't know. Have you tried using a clean debug ROM? What graphics plugin do you use? What are your debug ROM's settings? Link to comment Share on other sites More sharing options...
SanguinettiMods Posted October 10, 2012 Author Share Posted October 10, 2012 I can't tell if you're talking about my patched of Kaminotamashi's patches. Please explain and I will try to help you. Anybody that I've sent the patches to, they have worked perfectly fine without any problems like that; In fact, If it's any of my patches, I'm betting you are using a terribad graphics plugin. Posting an error report, at least in my experience should consist of all the neccesary factors. Have you tried using a clean debug ROM? What graphics plugin do you use? What are your debug ROM's settings? First, instead of saying something along the lines of: "It's not working! Help!" Now, things you can do to try. Use a program called GZRT to recalculate the CRC, if it's not broken, then good. Check your code list. There may be something interfering with my patches, causing your ROM to crash. Try different graphics plugins. Adjust your ROM settings, setting the CPU Core Style to Interpreter for a start. If none of these options work, try using Nemu, just to make sure it's not a faulty patch. Report back to me after you have tried all of these. EDIT: Problem solved. Both of those patches will not work at the same time. Don't try it. 1 Link to comment Share on other sites More sharing options...
pkjoan Posted November 17, 2012 Share Posted November 17, 2012 So I think there´s a problem with the patch, because I used the Debug rom with the exact same settings posted before and it works. But when I patch it gives me a horde of error messages. Link to comment Share on other sites More sharing options...
SanguinettiMods Posted November 17, 2012 Author Share Posted November 17, 2012 Both of them at the same time? Link to comment Share on other sites More sharing options...
pkjoan Posted November 17, 2012 Share Posted November 17, 2012 Never mind it was the rom, I downloaded another one and it worked. Thank you guys. EDIT: You can play as both Dark Link and MM Link if patched 2 in 1, the result will be a young link hitting puberty. Link to comment Share on other sites More sharing options...
