Ocarina Of Time ~ Debug ROM ALL Fixs ~
â–²ChriisTiianâ–²
I did this because the "ROM Fixer" from Zelda Edit doesn't work fine.
Btw, this patch allows fix many errors who Zelda Edit can't fix.
· [OoT Debug ROM Fix Patch]:
Download Patch: http://www.multiupload.nl/4ZB7S8OZX8
PPF o Matic: http://www.multiupload.nl/70RV2MQQNF
[Room 116]: Strongbox Warp.
· Added Loading Area Text.
[Room 117]: Bamboo Test (Collision Test Area).
[Room 118]: Test Map.
[Room 119]: Test Room (Treasure Chest Area).
· Fixed Loading Missing Room.
[Room 120]: Middle Stalfos Room.
· Added Correct Stalfos.
· Fixed Corrupted Header File (Only if you have the original Debug ROM).
[Room 121]: Boss Stalfos Room.
· Increased Light.
[Room 122]: Old Test (Enemy Test Area).
· Loaded Unused Actors.
[Room 124]: Depth Test.
· Removed JFIF Texture.
[Room 125]: Hyrulean Game 2.
· Fixed GPU Errors.
· Added BGM.
[GENERAL]:
· Fixed JaboD3D6, JaboD3D7 & JaboD3D8 Errors Possibilities.
· Fixed Zora's Fountain Cutscenes 01 & 02 Crashes.
· Fixed Kokiri Forest Cutscenes 04 & 05 Durations.
· Fixed Subscreen Delay.
· Fixed Ending Crash.
· Translated all Debug Options to English.
[Planned in the next version (4.0)]:
· Fix Zora's Fountain Scene 01. (?)
· Add more Configurations.
[Credits]:
SanguinettiMods
TS_Death_Angel
MNGoldenEagle
GlitterBerri
Dark-Link77
DeathBasket
cooliscool
Jaytheham
Bloodmoon
ZethAlkar
Cendamos
Spinout
& JSA
· [Graphic Plugin Configuration]:
· [JaboD3D6, JaboD3D7 & JaboD3D8]:
· [ROM Configuration]:
· [Nemu64]:
· [Project64 1.6]:
(Note: SP Hack is optional).
· [Project64 1.7]:
· [Project64 2.0, 2.1, etc]:
Looks like a good patch. I'll try it out when I can. Thanks for sharing. ^_^ I still have Zelda Edit and some places still wont work when ever I click "rom fixies" Also have you fixed the issue with Jabos Plugin for Pj64 1.6? Correct me if I made a typo. :)
  • 5 weeks later...
--- UPDATE:
· Fixed Camera Angles.
[GENERAL]:
· Fixed JaboD3D6 & JaboD3D8 Errors.
This Jabo's Fix help to reduce the possibility of errors from the video plugin.
If you want fix this completly, you need use another video plugin:
Rice's Video Plugin 6.1.1 beta10 (All Emulators)
Jabo's Video Plugin 1.7.0.57 (Project64 1.7)
Jabo's Video Plugin 1.6.1 (All Emulators)
Regards!
  • 4 months later...
Sorry for bump...
--- UPDATE:
[GENERAL]:
· Translated More Debug Options to English. ("FLAME" to "FRAME:").
· Fixed Kokiri Forest Scenes 04 & 05 Durations.
· Added Graphics Plugin & ROM Configuration.
Note: If you are using "Jabo's Direct3D8 1.6", you need download the new version: "Jabo's Direct3D8 1.6.1".
  • 3 months later...
Sorry for double post.
These aren't necessarily "fixed" haddockd. They're just mods that were either done by cooliscool's Zelda Edit or Otherwise. For example, the Stalfos aren't even "correct". It just suffices.
You're wrong. Compare this Stalfos with beta images & videos:
Stalfos Middle Room: rises out of the ground.
Stalfos Boss Room: jumps down from the sky when Link is near.
--- UPDATE:
· Fixed all "Use TLB" errors in Project64 2.0, 2.1, etc:
Now, if you apply this patch and you have "Use TLB" function enabled, you can access to Stalfos Middle Room & Hyrulean Game 2 without crash the game...
