Conker Posted February 7, 2013 Share Posted February 7, 2013 Warning! Image heavy!As the warning title states, this tutorial is indeed image heavy. Proceed at your own caution if this can have negative effects on your browsing experience. Just a heads up!Some games have music and sound effects mixed into a single file, so there are times you'll have to sift through many files to find what it is you're looking for, due to the program extracting the many sound effects of the game with the music files. Fortunately, not all games are like this. One more thing!If you want a higher sampling rate on the audio, it's best to go into the configuration window to adjust this setting, since by default, it has the sampling rate set to 22050. However, I do not recommend actually doing this, as for some reason, doing so in PSound makes the audio high-pitched. Only do so if you want to. To get to the configuration window, you can go to Options -> Configure. Or, you can just press CTRL+C in PSound. Once there, look for where it says "Sample Rate", there should be text that reads, "Force to". What you have to do is click on the box to the left of it, and then pick the sampling rate; try setting it to 44100 Hz. Now press "OK'. Okay, now get to work on extracting the music! Welcome to my tutorial! Now, keep in mind, you're going to need the following before we begin: PSound: http://snailrush.online.fr/ PS2 Game: DVD or ISO And, if at all relevant to your interests, I am pretty sure this works with PS1 games, as well! And yes, you can also extract other sounds besides music. Now, let's get to it! 2 Link to comment Share on other sites More sharing options...
gameus Posted February 7, 2013 Share Posted February 7, 2013 Very nice job Branden! Can't wait to use this tool, I've always wanted the music from Dark Cloud. <3 1 Link to comment Share on other sites More sharing options...
Conker Posted February 7, 2013 Author Share Posted February 7, 2013 Thanks, man! Glad you like it. Link to comment Share on other sites More sharing options...
Secant Posted February 8, 2013 Share Posted February 8, 2013 This is an awesome tutorial and I will probably be using this at some point or another. Much obliged, Blinx. 1 Link to comment Share on other sites More sharing options...
Conker Posted February 8, 2013 Author Share Posted February 8, 2013 Thanks, Naxy! Glad you've found it useful. Link to comment Share on other sites More sharing options...
SanguinettiMods Posted February 8, 2013 Share Posted February 8, 2013 Tekken Tag Tournament needs a little...opening up. You know. To see what's inside. Gosh. Link to comment Share on other sites More sharing options...
Netsrac Posted February 8, 2013 Share Posted February 8, 2013 Does it also work with PAL games? I can´t wait to have Kingdom Hearts music on my iPod <3 Link to comment Share on other sites More sharing options...
Conker Posted February 8, 2013 Author Share Posted February 8, 2013 Does it also work with PAL games? I can´t wait to have Kingdom Hearts music on my iPod <3 I don't see any reason why not. Link to comment Share on other sites More sharing options...
Conker Posted February 8, 2013 Author Share Posted February 8, 2013 I updated the tutorial with info about the sampling rate I think a lot of you would find useful. Link to comment Share on other sites More sharing options...
