Okay, I think I figured out what went wrong...but I'm not sure how to fix it. I was using ZAO-ADD to put some push blocks into Room 11 of the Forest Temple for a new puzzle. But the thing is, there's not enough space in the room at the point where the room is normally, so I had the program use the offset 0x35CE040.
However, I think 0x35CE040 is where I put Hyrule Field earlier. I'm 100% 90% sure that's why this happened.
This is the code I have at this offset:
16 00 00 00 00 00 00 0A 08 01 00 00 00 00 00 00
12 00 00 00 01 01 00 00 10 00 00 00 FF FF 00 00
0A 00 00 00 03 00 01 C0 0B 0D 00 00 03 00 AB E0
01 23 00 00 03 00 AD 8A 14 00 00 00 00 00 00 00
Not sure if this helps or not.
When I go into Hyrule Field, this is what happens:
Now...the question is...how does one fix it? How do I get Hyrule Field to come back? I do have a backup ROM, but I'd like to know a way to fix this if it's possible.
giadrosich
...help....
100%90% sure that's why this happened.This is the code I have at this offset:
4 answers to this question
