Help with replacing link object model
LingeringWraithX
4 answers to this question
Its this part that isn't made clear to me
if you plan to import the Display Lists one-by-one, you can go ahead and export an OBJ of this now. If you plan to import them all from the same OBJ file, make sure this new hand is its own component and delete the previous one. the new one's visibility to Hidden so it isn't in the way when placing the others
That simply states that if you want to convert each display list one-by-one, you can export an OBJ of what you're working with out of SketchUp right there. If you don't want to do it one-by-one, however, you can hide the display list you're currently working with so you can place the other ones in SketchUp.
