Enable audio debugger in MM debug ROM
DeathBasket
I don't think this was found before, but I found this just now. The audio debugger can be enabled with the gameshark code 813E416C 0001. The controls are the same as the menu in OoT - use the fourth controller, l/r to change page, d-pad to select/change a value, a and b to mute/unmute and play bgm/sfx.
