Please help me
Your Local Cultist
Apparently the program is complaining that OpenTK (?) isn't installed and therefore functions used to utilize OpenTK within the python script are invalid. I also noticed that you have Python v3.3 installed... you need Python v2.5 (or v2.6?) for most of spinout's python scripts to run correctly.
I used spinout's porter quite often and I don't think I've run into any issues. Do you have vPython installed as well? I think it requires both Python and vPython in order to work and along with having the same version which I'm not sure is a requirement but I use version 2.6 for (v)Python so the two will play nicely with each other.
