Problems with ZAP2.
Armos
I'm using ZAP2 "Zelda Actor Replacement" to edit some areas in levels, I never had any trouble with this before or had an issue. You set everything up as normal, even read through the instructions it's been awhile when I messed with the program. I'm trying to change Dark Link's actor in Sutaru zmap to test things out. Having some issues with replacing Dark Link's actor. The menu wont let me click on "Save To ROM" or "Save to RAM" when ever I change the variables or the actor numbers. Is there anything I'm doing wrong with the program? Like I've said I haven't touched the program in ages and I'm having some trouble trying to make edits. And when I change the groups in the group editor. Even though I save it when it's replaced it ends up back with Dark Link's variable. Hoping for advice.
EDIT: Problem solved. Can someone please close the thread. Thank you.
1 answer to this question
Guest
This topic is now closed to further replies.
