Majoras Mask and Ocarina of Time MIDI Instruments.
Stryfe
Hello again everyone,
I am curious if it is possible to load MIDI instruments form Ocarina of Time or Majoras Mask and Create sequences with them.
Similar to how the music was composed for the URA project awhile back.
What sort of suggested programs or modifications can do this? I have done quite a bit of research but I cannot find the correct means of doing so.
Any suggestions?
-Stryfe
You can rip instrument samples as wave files using N64 sound list tool. When you have a set of samples you can make a soundfont with them and then use that as a sound set to play back MIDI files with in certain programs. punk7890 has made a few soundfonts including one for OoT so you should check that out, it's somewhere on this forum.
Edit: here https://www.the-gcn.com/topic/2503-ocarina-of-time-soundfont-update/
