Twili Posted January 14, 2015 Share Posted January 14, 2015 I'm making this as a counterpart to the topic on GBAtemp. The Wii U common key has been leaked, so we have the ability to decrypt ISOs now, though the process hasn't been clearly defined yet. This means that the stage models from Hyrule Warriors that crediar didn't share with me can be gotten now, and that updated Zero Suit Samus and her alt costumes can be rigged once Smash 4's compression is figured out. Also curious to see if The Wind Waker HD has any test maps left in it. Edit: Use this to browse + extract .szs archives: https://www.dropbox.com/sh/tfg2nd6q809oqn3/AAAmO-UnYwuVOWhI30oWhX0ja/WiiUExplorer%20(new)/WiiUExplorer_v1.0.4.0.zip?dl=0 5 Link to comment Share on other sites More sharing options...
Twili Posted January 17, 2015 Author Share Posted January 17, 2015 Hey, look, I extracted Wind Waker HD: https://mega.co.nz/#!QV4GTRhB!ts8f0c1OVas375y-xpvKzuWouerMC1hkL1Hw9XMsOk8 And here's the file list: http://pastebin.com/raw.php?i=swA2i1aW Of note: [2C1] CID:0B Size:0013AD78 Offset:0x00026C5FE0 [content/Common/Stage/ITest61_Room0.szs] [2C2] CID:0B Size:0015316E Offset:0x0002800D60 [content/Common/Stage/ITest61_Room1.szs] [2C3] CID:0B Size:00136E54 Offset:0x0002953EE0 [content/Common/Stage/ITest61_Stage.szs] [2C4] CID:0B Size:00153080 Offset:0x0002A8AD40 [content/Common/Stage/ITest62_Room0.szs] [2C5] CID:0B Size:0000523C Offset:0x0002BDDDC0 [content/Common/Stage/ITest62_Stage.szs] [2C6] CID:0B Size:001BC3B8 Offset:0x0002BE3000 [content/Common/Stage/ITest63_Room0.szs] [2C7] CID:0B Size:0000523F Offset:0x0002D9F3C0 [content/Common/Stage/ITest63_Stage.szs] There's likely more interesting stuff, because I don't remember the filenames from the SD (GameCube) version all that well. Let's explore... For those with Wii U ISOs, I used this to extract the files: http://crediar.no-ip.com/DiscU_2.1b-cred.rar You may also need this to use it: http://www.dll-files.com/dllindex/dll-files.shtml?msvcr120 Click DOWNLOAD ZIP-FILE and download the 32bit one. It should go in the folder where DiscU is. For more information, ask me. 1 Link to comment Share on other sites More sharing options...
Kargaroc Posted January 17, 2015 Share Posted January 17, 2015 Of course all the file formats are completely different. >.< I don't have a tool that can extract SARC files currently either. Link to comment Share on other sites More sharing options...
Twili Posted January 17, 2015 Author Share Posted January 17, 2015 This part of the Iwata Asks is worth reading: http://iwataasks.nintendo.com/interviews/#/wiiu/wind-waker/0/3 Iwata: Three designers? Considering the deadline, even though it was a remake, correcting each bit of data by hand would be impossible. Dohta: Yeah. Actually, designers in-house that could work on this were limited since it needed to be people who were familiar with the data and direction of the original designs. We knew we weren’t able to rely on a workflow that employed a lot of people. So this time we used a special method. We devised a way to convert Nintendo GameCube data for the Wii U and to make visuals look better, while hardly laying our hands on the 3D modeling data. So it should be easy to write a viewer, it sounds like, by comparing files from both versions. 3 Link to comment Share on other sites More sharing options...
Twili Posted January 18, 2015 Author Share Posted January 18, 2015 The following stages had these rooms removed in the HD version: M_NewD2: Room 9 PShip: Room 0 and 1 sea: Room 0, 1, 9, 13, 17, 23, 39, 41, and 44 TF_03: Room 1, 2, 3, 4, 5, and 6 And these stages were removed entirely: A_R00 Amos_T H_test I_TestM I_TestR KATA_HB KATA_RM K_Test2 K_Test3 K_Test4 K_Test5 K_Test6 K_Test8 K_Test9 K_Testa K_Testb K_Testc K_Testd K_Teste morocam Name sea_LOD01 - sea_LOD49 SubD45 TEST TF_05 TF_07 VrTest 2 Link to comment Share on other sites More sharing options...
Zeth Ryder Posted January 25, 2015 Share Posted January 25, 2015 Were you able to get all the Hyrule Warriors files dumped yet? Also great job on the Wind Waker HD dump! Link to comment Share on other sites More sharing options...
Twili Posted January 28, 2015 Author Share Posted January 28, 2015 Thanks! And yes, I dumped Hyrule Warriors, but EVERY model is zlib-compressed, so uploading them will be a pain, since they don't compress well. But here's the models from the latest DLC: http://soneek.info/model.7z Etc. 6 Link to comment Share on other sites More sharing options...
Twili Posted February 5, 2015 Author Share Posted February 5, 2015 Never mind. Link to comment Share on other sites More sharing options...
Zeth Ryder Posted February 6, 2015 Share Posted February 6, 2015 Never mind. Feels like there is an update missing on the Hyrule Warriors stuff? How goes it man? I know Chroxx on the Facepunch forums has been wanting to get those map files so he can add support to Noesis. Link to comment Share on other sites More sharing options...
