MM 3D - Model Format discussion
Twili
No problem, that link was more or less just for reference for the rest of the thread. I figured the original code would be more difficult to compile - like with the usage of the Boost library in util.cpp, tho I never used that lib before (and it appears to only be used for some path handling there...?) - so a simple, standalone C version is nice to have.
So, I discovered that it's incredibly easy to dump games via Gateway's Launcher.dat and generate xorpads to decrypt them via another homebrew Launcher.dat and took some pics and a video to celebrate.  ^_^
Shown is the dumping of Majora's Mask 3D...
And here's a GAR extractor I wrote in C.
#include <stdio.h>
int main(int argc, char **argv)
    FILE *gar, *out;
    unsigned int files,len,off,path,sizes,y;
    unsigned short count,x;
    char longname[97], shortname[65], check=1;
    gar=fopen(argv[1],"rb");
    fseek(gar,0xA,SEEK_SET);
    count=(unsigned short)(fgetc(gar)|(fgetc(gar)<<8));
    fseek(gar,4,SEEK_CUR);
    sizes=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24));
    files=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24));
    for(x=0;x<count;x+=1)
        fseek(gar,files+4*x,SEEK_SET);
        off=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24));
        fseek(gar,sizes+12*x,SEEK_SET);
        len=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24));
        path=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24));
        fseek(gar,path,SEEK_SET);
        while(check!=0){check=fgetc(gar);}
        while(check!=0x2F)
            fseek(gar,-2,SEEK_CUR);
            check=fgetc(gar);
        fgets(shortname,65,gar);
        fgets(longname,97,gar);
        out=fopen(shortname,"wb");
        printf("Extracting file %d...\n%s\n",x,longname);
        fseek(gar,off,SEEK_SET);
        for(y=0;y<len;y+=1){fputc(fgetc(gar),out);}
        fclose(out);
    return 0;
xdan, here's my latest notes on animations:
Any sample values provided are as they appear in little endian. This also focuses on the MM3D spec, which is a tad different than the OoT3D one, just like model data.
CTR Skeletal Animation Binary (*.csab)
0x0: magic "csab"
0x4: file size (u32)
0x8: version (u32, 05000000 = MM3D) (OoT3D is 03000000)
0xC: always 00000000? (u32)
0x10: 3 unknown floats?
0x1C: always 01000000? (u32)
0x20: animation node (anod) base (u32)
0x24: padding
0x34: frame count, minus 1 (u32)
0x38: unknown property (u32, seen 01000000 and 00000000)
0x3C: anod count (u32)
0x40: bone count (u32)
0x44: bone table (2*bone count in size)
Contains signed shorts (16-bit), if set to -1 (FFFF) the bone has no anod, else is the anod number for the bone.
2 bytes of padding after if the bone count is odd-numbered.
0x(varies): anod table (4*anod count in size)
Immediately after the bone table (+padding noted above), contains relative u32 pointers (to the anod base) to each anod.
anod:
0x0: magic "anod"
0x4: property 1 (u16, if set to 0000, the anod is empty, AKA same as a bone not having an anod. Weird.)
0x6: property 2 (u16, unknown purpose)
0x8: transformation table
Contains 6 u16 pointers, relative to the start of the anod:
+0x0: X rotations
+0x2: Y rotations
+0x4: Z rotations
+0x6: X translations
+0x8: Y translations
+0xA: Z translations
If any of these are set to 0, the transformation is locked. (0 for all frames)
0x14: 8 bytes of padding
Rotation/translation data:
+0x0: unknown property (u16)
+0x2: unknown property (u16)
+0x4: unknown float
+0x8: unknown float
+0xC: rotation/translation for each frame (u16) (rotations need to be converted to degrees the same way as N64 Zeldas)
Hope something comes of this! I want some kind of video or GIF demonstrating an animation if this works, even if it's just the skeleton.  ;)
Also, any of Link's animations have a larger bone table than he has bones, for some reason. More research will be needed for Link's special case.
