xdaniel Posted March 19, 2015 Share Posted March 19, 2015 No problem, that link was more or less just for reference for the rest of the thread. I figured the original code would be more difficult to compile - like with the usage of the Boost library in util.cpp, tho I never used that lib before (and it appears to only be used for some path handling there...?) - so a simple, standalone C version is nice to have. Link to comment Share on other sites More sharing options...
Twili Posted March 20, 2015 Author Share Posted March 20, 2015 So, I discovered that it's incredibly easy to dump games via Gateway's Launcher.dat and generate xorpads to decrypt them via another homebrew Launcher.dat and took some pics and a video to celebrate. Shown is the dumping of Majora's Mask 3D... 1 Link to comment Share on other sites More sharing options...
Twili Posted March 20, 2015 Author Share Posted March 20, 2015 And here's a GAR extractor I wrote in C. #include <stdio.h> int main(int argc, char **argv) { FILE *gar, *out; unsigned int files,len,off,path,sizes,y; unsigned short count,x; char longname[97], shortname[65], check=1; gar=fopen(argv[1],"rb"); fseek(gar,0xA,SEEK_SET); count=(unsigned short)(fgetc(gar)|(fgetc(gar)<<8)); fseek(gar,4,SEEK_CUR); sizes=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24)); files=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24)); for(x=0;x<count;x+=1) { fseek(gar,files+4*x,SEEK_SET); off=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24)); fseek(gar,sizes+12*x,SEEK_SET); len=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24)); fseek(gar,4,SEEK_CUR); path=(unsigned int)(fgetc(gar)|(fgetc(gar)<<8)|(fgetc(gar)<<16)|(fgetc(gar)<<24)); fseek(gar,path,SEEK_SET); while(check!=0){check=fgetc(gar);} while(check!=0x2F) { fseek(gar,-2,SEEK_CUR); check=fgetc(gar); } fgets(shortname,65,gar); fseek(gar,path,SEEK_SET); fgets(longname,97,gar); out=fopen(shortname,"wb"); printf("Extracting file %d...\n%s\n",x,longname); fseek(gar,off,SEEK_SET); for(y=0;y<len;y+=1){fputc(fgetc(gar),out);} fclose(out); } return 0; } 1 Link to comment Share on other sites More sharing options...
Vexiant Posted March 22, 2015 Share Posted March 22, 2015 that face Link to comment Share on other sites More sharing options...
PwnzLPs Posted March 29, 2015 Share Posted March 29, 2015 Is there a way to incorporate an animation into the export? Link to comment Share on other sites More sharing options...
Twili Posted May 16, 2015 Author Share Posted May 16, 2015 xdan, here's my latest notes on animations: Any sample values provided are as they appear in little endian. This also focuses on the MM3D spec, which is a tad different than the OoT3D one, just like model data. CTR Skeletal Animation Binary (*.csab) 0x0: magic "csab" 0x4: file size (u32) 0x8: version (u32, 05000000 = MM3D) (OoT3D is 03000000) 0xC: always 00000000? (u32) 0x10: 3 unknown floats? 0x1C: always 01000000? (u32) 0x20: animation node (anod) base (u32) 0x24: padding 0x34: frame count, minus 1 (u32) 0x38: unknown property (u32, seen 01000000 and 00000000) 0x3C: anod count (u32) 0x40: bone count (u32) 0x44: bone table (2*bone count in size) Contains signed shorts (16-bit), if set to -1 (FFFF) the bone has no anod, else is the anod number for the bone. 2 bytes of padding after if the bone count is odd-numbered. 0x(varies): anod table (4*anod count in size) Immediately after the bone table (+padding noted above), contains relative u32 pointers (to the anod base) to each anod. anod: 0x0: magic "anod" 0x4: property 1 (u16, if set to 0000, the anod is empty, AKA same as a bone not having an anod. Weird.) 0x6: property 2 (u16, unknown purpose) 0x8: transformation table Contains 6 u16 pointers, relative to the start of the anod: +0x0: X rotations +0x2: Y rotations +0x4: Z rotations +0x6: X translations +0x8: Y translations +0xA: Z translations If any of these are set to 0, the transformation is locked. (0 for all frames) 0x14: 8 bytes of padding Rotation/translation data: +0x0: unknown property (u16) +0x2: unknown property (u16) +0x4: unknown float +0x8: unknown float +0xC: rotation/translation for each frame (u16) (rotations need to be converted to degrees the same way as N64 Zeldas) Hope something comes of this! I want some kind of video or GIF demonstrating an animation if this works, even if it's just the skeleton. Also, any of Link's animations have a larger bone table than he has bones, for some reason. More research will be needed for Link's special case. 1 Link to comment Share on other sites More sharing options...
