Only 2 issues plaguing my mod (at least for now)
haddockd
Hi All,
I have imported music (from MM) for 2 areas in my mod and the music doesnt loop. Is there a quick hex change I can make to make these tracks loop?
I am having issues finding the proper map offsets for Kokiri forest and Skulltullas. Essentially I placed a few in the map before you beat the Deku Tree but once you do, that map is no longer used so the Skulltulla is no longer there. Anyone know that offset (kid, post Deku Tree)?
1 answer to this question
Hi All,
There is a byte at the end of the file that makes it loop, and I'm pretty sure it works like OoT's music... but I'm not sure if the byte does it alone, because I think there's also a code used to identify if it loops.
This might help you: http://wiki.spinout182.com/w/Music_Sequences
