Destroyer4292 Posted April 30, 2011 Share Posted April 30, 2011 I'm not sure, but is there a way that adult Link can use items only meant for kid Link? For example, the slingshot and the boomerang. I had an idea of making the boomerang into a magic shuriken for my Sheikah mod. Link to comment Share on other sites More sharing options...
0 Mellow Posted April 30, 2011 Share Posted April 30, 2011 I'm not sure, but is there a way that adult Link can use items only meant for kid Link? For example, the slingshot and the boomerang. I had an idea of making the boomerang into a magic shuriken for my Sheikah mod. Sheikah mod... like... Link as a sheikah!? Link to comment Share on other sites More sharing options...
0 Destroyer4292 Posted April 30, 2011 Author Share Posted April 30, 2011 *Cough* http://core.the-gcn.com/index.php?/topic/407-the-legend-of-zelda-shadows-of-hyrule/ Link to comment Share on other sites More sharing options...
0 Jason777 Posted May 3, 2011 Share Posted May 3, 2011 Just delete my above post because it is meaningless considering that I took a closer look at the OP. Here is what you must do to be able to use the boomerang as and adult: •Go to 0xBF9B18 in the ROM •Change the byte located at that offset to "00" That makes the item usable as ONLY adult link. To make it ONLY usable as child link, change the byte to "01". If you want to use the item as both child and adult link, change the byte to "09" Now, we need to make the item highlighted when selecting it: •Go to 0xBF9B42 in the ROM •Change the byte located there to "00" The same rules apply to both the item usability and highlight. Next, we need to make the model show up in adult Link's hand: Now I haven't tried this out for myself (yet) but, hey, it's all I got... As for making the boomerang appear for adult link, search ovl_player_actor for child link's boomerang, and near it there should be 00000000. Change this to your ported boomerang, and it should work out. Hope, that helps! Link to comment Share on other sites More sharing options...
0 Destroyer4292 Posted May 3, 2011 Author Share Posted May 3, 2011 Ok. Are you supposed to do this in Uot or with a hex editor because I have both Uot and xv132. Link to comment Share on other sites More sharing options...
0 Jason777 Posted May 3, 2011 Share Posted May 3, 2011 Hex editor of your preference Link to comment Share on other sites More sharing options...
0 Destroyer4292 Posted May 3, 2011 Author Share Posted May 3, 2011 Ok I followed the instructions and nothing happened. Link to comment Share on other sites More sharing options...
0 Jason777 Posted May 5, 2011 Share Posted May 5, 2011 What part of it did not work? Link to comment Share on other sites More sharing options...
0 SanguinettiMods Posted May 7, 2011 Share Posted May 7, 2011 Basically you go to the offset and change the byte to the needed specs. You can make it usable, but the model wont show up. (The boomerang) Adult Link can use it. But unless you hack it correctly (See Flotonic) The model wont show. Link to comment Share on other sites More sharing options...
Destroyer4292
8 answers to this question
