Pinkie Pie Posted May 9, 2011 Share Posted May 9, 2011 I can't just seem to get my shield texture for my Manga Link to load >.< I have it named correctly but it just won't load. I am using Mudlord's Rice Video Build 6.1.4 and here is the texture: http://tinypic.com/view.php?pic=2j4ouon&s=7 Link to comment Share on other sites More sharing options...
0 Secant Posted May 9, 2011 Share Posted May 9, 2011 Please provide the texture that you're attempting to load as well as the plugin you're using, otherwise there's not much we can do to offer help. Link to comment Share on other sites More sharing options...
0 Pinkie Pie Posted May 10, 2011 Author Share Posted May 10, 2011 Please provide the texture that you're attempting to load as well as the plugin you're using, otherwise there's not much we can do to offer help. Okay fixed it, sorry, I was in a bit of a rush when I originally wrote this http://core.the-gcn.com/public/style_emoticons/default/teehee.gif Link to comment Share on other sites More sharing options...
0 Secant Posted May 11, 2011 Share Posted May 11, 2011 Unless I'm mistaken, Mudlord's plugin only supports up to quadruple-sized textures, so in the case of the shield texture, the maximum dimensions allowed are 128x256. Yours is twice that (8x the original), and thus cannot be loaded by Mudlord's plugin. You can either halve the texture size, or use a newer version of the Rice-generation plugin series (i.e. Aristotle's, which supports up to 128x, or 1964, which has the latter and greater stability/options). Link to comment Share on other sites More sharing options...
0 Pinkie Pie Posted May 11, 2011 Author Share Posted May 11, 2011 Unless I'm mistaken, Mudlord's plugin only supports up to quadruple-sized textures, so in the case of the shield texture, the maximum dimensions allowed are 128x256. Yours is twice that (8x the original), and thus cannot be loaded by Mudlord's plugin. You can either halve the texture size, or use a newer version of the Rice-generation plugin series (i.e. Aristotle's, which supports up to 128x, or 1964, which has the latter and greater stability/options). Hmm I am now using Aristotle's Mudlord's and Rice Video and the game crashes past the N64 screen.. and then I used 1964 community version....and it again doesn't load the shield texture Link to comment Share on other sites More sharing options...
0 Secant Posted May 13, 2011 Share Posted May 13, 2011 The shield texture has, in general, often been very problematic. In many instances it won't load for unknown reasons; I would recommend trying a shield texture that you know loads, and replace it with your image and save it within the hires_texture folder. Beyond that, I can't recommend much; I had similar troubles with that texture, and I have no idea how I managed to fix the problem, other than spamming saving it over various working textures. Sorry I can't offer much more help than that. Link to comment Share on other sites More sharing options...
0 Pinkie Pie Posted May 13, 2011 Author Share Posted May 13, 2011 The shield texture has, in general, often been very problematic. In many instances it won't load for unknown reasons; I would recommend trying a shield texture that you know loads, and replace it with your image and save it within the hires_texture folder. Beyond that, I can't recommend much; I had similar troubles with that texture, and I have no idea how I managed to fix the problem, other than spamming saving it over various working textures. Sorry I can't offer much more help than that. http://core.the-gcn.com/public/style_emoticons/default/confused.gif That's actually what I did, I replaced Zeth's texture and it doesn't load Link to comment Share on other sites More sharing options...
Pinkie PieI can't just seem to get my shield texture for my Manga Link to load >.< I have it named correctly but it just won't load.
6 answers to this question
