The Black Marsh
Mellow
  • Replies 212
  • Created
  • Last Reply
Top Posters In This Topic
Calm brother, you must do this soundly. From what I've heard from the townsfolk, he's staying at the local inn. If we just storm in, this could turn into a hostage situation. I believe we should put on some normal clothing and sneak in, even if its against our code. Not only that, but I think only I should enter. There's no doubt in my head that he's already memorized what you look like. So here's the plan. I'm going to find Idhara, get her outta there, and you can deal with the pigman yourself.
No, we're doing this now. I want to make sure our sister is out of harms way. -Sneaks into the inn- Hmm, now where could she be possibly be. Probably locked in one of these rooms... -Looks through a lock- Not this one... Let's try this one. -Sees a young Khajit girl. There are guards around the corner of the door.- Well, here's what I'm gonna do... -Picks the lock on the door and opens it quickly, knocking out one guard, then quickly stabs the other guard.- Idhara! Come with me, we're getting you outta here!
Haha, how wrong you are. And don't think your Chameleon will work here, Argonian. I can see through any form of camouflage. -Tackles J'Ram-Ku- And besides, stealth can't do much for yourself when your opponent knows exactly where you are. -Grabs his daedric dagger, and stabs the Argonian in the leg, nailing him to the floor-
-Smacks the Argonian back down, and takes the Daedric dagger out of his hand- Oh, can't stand up? I'm sorry, I shouldn't have pushed you down. Here, maybe this will help. -Stabs the dagger into J'Ram-Ku's right wrist, once again nailing him to the ground- What're you going to do now? There's nothing you CAN do. You failed, and now you will die like the heartless killer you are.
Argh... Not much pain, but you've frozen my left thumb and index finger. Too bad I don't use those fingers. -Tackles J'Ram-Ku into a wall, and stabs both hands into the wall- You can't stop me, boy. -Gets out his torch, and lights the place on fire- I'd like to see you try and escape, boy, you have no chance. I'll see you on the flips side. -Dashes out the front door without anyone but J'Ram-Ku seeing him.
Dammit... the rat got away...
-struggles a bit-
They don't seem that tough...
-pulls his right hand from the dagger in the wall, ripping the dagger clean through his wrist-
Hsss... Just... one more to go...
-grabs the dagger with his badly wounded right hand and pulls the dagger out with minimal damage to his left hand-
By Sithis... such a troublesome rat... I'll have to report my failure to Odral...
-wraps a nearby piece of cloth tightly around his right wrist to stop the bleeding-
That should hold me long enough to get to a doctor...
-begins hobbling to the exit, wincing with each step-
We'd best hurry... unless you'd like me to die before we even get there.
What all did he do to you... Brother?
He had the idea that he could pin me to the wall or floor and then finish me off while I was pinned... but he kept forgetting that he was dealing with a Dark Brotherhood assassin, so he fled, fearing for his own life.
Brother, he is a higher ranking than I would be if I were apart of them. And if he nailed you to a wall, leaving you unable to move, why wouldn't he kill you right then and there? No, brother, I believe he ran because he saw something in you.
