Item hacking halp.
SanguinettiMods
I'm not exactly sure how to word this, so I'll give an example.
Remember in Spinout's "Zelda's Birthday" hack? Link gets the Megaton Hammer. Normally in any other game, a model wouldn't load when you equip it. But it does in Zelda's Birthday.
Can anyone help me figure out how to do that? Specifically with the Master Sword, and/or Biggoron's sword. Link isn't going to get the master sword, but rather a more powerful sword than the Kokiri Sword, and I would like to know how to:
>When Link receives the Item, the Master Sword (Not the Master Sword in this game) Becomes Available on the sub-screen.
>When Link Equips that, the Item model actually loads.
>Achieve Happiness.
25 answers to this question
> This is easy enough to understand, but doesn't quite answer my question.
> I don't quite get what this is... EDIT: Nevermind.
> Haha, Alright.
EDIT AGAIN
Basically, What I want, when Child Link has the Master Sword Equipped, 0x15540 loads instead of 0x13F38, but as you said, the Master Sword Requires a hack.
Tools Needed : HxD
First open in HxD
Obj_link_Boy
copy >10EE8 - 1175D
length 876
>Paste in Obj_link-child
>D690 - Df05
{all this does is flip the model to be the same position as the adult Link Master Sword.}
then goto 0x15540
>Select block 0x15540
then for the length put 410 copy it
>then goto 13f38 then paste it at that address.
>Next after you paste it you should see E6, change that to DF.
at the address 14350 put E7 00 00 00 00 00 00 00
save and your done
{This then replaces the display list(I don't the the proper term name?) of the Kokiri Sword, Then copies The Master sword at the address 0x13f38.
There is also a gameshark code I have that's loads the address 0x15540 Correctly with no errors over the kokiri sword I'll post it when I go back to my Dad's on Friday.
For some reason it comes out the right arm comes out messed up when I equip the hylian shield but perfect when I use the deku shield and have the sword drawn.
wierd?
Oh, did you mean receiving the item from a chest? In that case, read this.
The Master Sword is item 3C, but you'll have to make your own GI object for it. The shader should be the same as for the object you replace.
To make it work properly:
.org 0x8008EB84
	j         0x80700000
	sll       t2,t1,0x2
.org 0x80700000
	lb        t0,0x0068(v1) //get b button equip
	addiu     t0,t0,0xFFC4  //-0x3C (Master Sword value)
	bne       t0,$zero,end  //if it's not equipped then go to end
	addu      t7,t2,t6
	lui       t6,0x8012
	addiu     t6,t6,0x5E3C  //what pointer should be if sword is being used
	beql      t7,t6,end     //if equal to what pointer is
	addiu     t7,t7,0xFFF0  //-0x10 from it
end:
	j         0x8008EB8C
	nop
gameshark:
  Reveal hidden contents
That will load the (unused?) pointer from 0x10 before the pointer it usually loads if the Master Sword is equipped. You'll want to change the pointers at 0xB9CFCC and 0xB9CFD4 in ROM to point to your new model.
If you want to patch the code to ROM then I can show you how and where to put it.
.org 0x8008EB84
j     	0x80700000
sll   	t2,t1,0x2
.org 0x80700000
addu      t7,t2,t6
lui   	t6,0x8012
end:
j     	0x8008EB8C
nop
gameshark:
Yes, Deathbasket. I was planning on having my new sword come from a chest. If you don't mind, do you think you'd be able to get on skype, or some other place to show me how these "Shader Commands?" Work? thumbsup.gif It's probbaly immensely easy to understand, but I'm just not getting it.
To be honest I'm not entirely sure what they are, I just know you need to use the same one as the GI object you're replacing uses.
As an example, let's say you're replacing the boomerang's chest entry.
  Quote
start byte 0x00C224c4
end byte 0x00C227AA
ii ff xx mm yyyy
Every 6 bytes is a corresponding entry on the chest actor's variable.
ii = item gained
ff = flag
xx = shader
mm = message #
yyyy = model
--GI_object:shader combos--
00E8:34 = boomerang
At 0xC224E2 we see:
0E 80 34 35 00E8
0E = item
80 = flag (?)
34 = shader
35 = message
00E8 = object
So to get the Master Sword from this you would just change the item number to 3C, then swap the boomerang's model with your sword. You'd then have:
3C 80 34 35 00E8
But if you changed the object number then you'd have to update the shader. So if your model replaced the GI object for Zelda's Letter instead for example:
  Quote
00EF:3B = Zelda's Letter
The entry for your item would now be:
3C 80 3B 35 00EF
So then by using a chest with the variable that usually gives you the boomerang you'd get the Master Sword but Zelda's Letter would show up as the GI object and the text would be for the boomerang.
Sorry if what I said isn't totally correct, it's been ages since I did this.
Thank you so much!
At the same time, though, That would enable me having the Master Sword through a Chest, But what abut Child Link actually being able to use it? I can enable him to equip it, but the model for the Kokiri Sword is loaded instead. I'm not sure if that hack you posted earlier was for that or not.
  On 8/9/2011 at 9:52 PM, 'SanguinettiMods' said:
Thank you so much!
Your trying to load the the sword at the Address 0x15540(Master Sword) right?. Just use this Gameshark code it only works for young Link only, sadly. If you use it as adult Link the graphics will distort.
80224717 0004 Giving credit to DeathBasket, too.
It load the Address 0x15540 and puts it over the Kokiri sword, what ever it may be. Hope's this helps.
or
If you just want to use the Master sword as young make sure you follow this method otherwise link will hold it backwards, If not you now have the code needed to load objects from the address 0x15540 http://core.the-gcn.com/public/style_emoticons/default/thumbsup.gif
Tools Needed : HxD
First open in HxD
Obj_link_Boy
copy >10EE8 - 1175D
length 876
>D690 - Df05
Example
First I was like "wat" and then I remembered I posted that code over two years ago, heh. The code I posted earlier in this thread will do exactly the right thing as long as you fix the pointers in ROM that I mentioned. Give it a try. http://core.the-gcn.com/public/style_emoticons/default/thumbsup.gif
  On 8/12/2011 at 11:52 PM, DeathBasket said:
First I was like "wat" and then I remembered I posted that code over two years ago, heh. The code I posted earlier in this thread will do exactly the right thing as long as you fix the pointers in ROM that I mentioned. Give it a try. thumbsup.gif
Deathbasket, You mentioned patching the code to the ROM. I'm planning on using this for a mod, so do you think you could tell me how and where to put it?
Okay. We need a RAM address that's always going to be in the same spot and isn't going to be overwritten. We can use 0x8001CD60, which is free space at the end of the file table (thanks petrie911).
So now we need to convert these RAM addresses to ROM addresses.
0x8008EB84 is in code, at 0x00B05D24 in ROM. Go there and write:
0800 7358
0009 5080
The rest of the code will now be at 0x8001CD60, which turns out to be at 0x00018F30 in ROM so go there and write:
8068 0068
2508 FFC4
1408 0005
014E 7821
3C0E 8012
25CE 5E3C
51CF 0001
25EF FFF0
0802 3AE3
0000 0000
You'll now have to fix the CRC because of where the code was inserted.
Works fine on Nemu for me but you're right about Project 64. To get it to work on Project 64 you need to leave a blank line at the end of the file table.
Go back to 0x00B05D24 in ROM and write this line instead:
0800 735C
Then write the rest of the code at 0x00018F40 rather than 0x00018F30 and fix the CRC again.
  On 8/13/2011 at 4:36 PM, DeathBasket said:
If it doesn't work this time then PM me a patch of your ROM so I can check what you've done and see why it's not working.
Alright. Sadly it still didn't work. But for some reason, the same thing happens to music hacks now, when I fix the CRC. It does the same thing.
PJ64 has to enable/disable game specific hacks for the games to work. When you change a ROM's CRC, PJ64 no longer enables/disables the hacks, and it runs it as an "unknown" ROM. Try setting the r3400i core to pure interpreter, and setting the game settings correctly.
Or use Nemu :D
