[ubuntu] I cannot get Mupen64Plus working!
Andreawws!
<console_dump>
haxxor@haxxorz-Domainz:~$ mupen64plus[/s] __ __ __ _ _ ____ _ | \/ |_ _ _ __ ___ _ __ / /_ | || | | _ \| |_ _ ___ | |\/| | | | | '_ \ / _ \ '_ \| '_ \| || |_| |_) | | | | / __| | | | | |_| | |_) | __/ | | | (_) |__ _| __/| | |_| \__ \ |_| |_|\__,_| .__/ \___|_| |_|\___/ |_| |_| |_|\__,_|___/ |_| http://code.google.com/p/mupen64plus/ Mupen64Plus Console User-Interface Version 1.99.4 dlopen('./libmupen64plus.so.2') error: ./libmupen64plus.so.2: cannot open shared object file: No such file or directory AttachCoreLib() Error: failed to find Mupen64Plus Core library
</console_dump>
So...
Can anyone give me a hint on this?
Thanks in advance /Andreawws!
Topic solved, let's let it die in peace.
4 answers to this question
You should probably say how you solved it and add [sOLVED] to the title so people having trouble in the future can fix the problem.
This. I'll lock the topic and rename it if necessary when Andreawws adds the solution there; resolved help topics are our best friends because they save us from redundant question threads.
How I solved it?
Uninstalled it
Reinstalled it
same problem then I:
F-ed around with new libraries (libpng is one) the files (adding symbolic links)
And generally breaking everything.....
well obviously not breaking, since it worked...
And I would have changed the title, but I didn't see anywhere to do that when I edited the topic.....
**Note that is a quick description of what I did**
