xdaniel Posted September 20, 2011 Author Share Posted September 20, 2011 On 9/19/2011 at 2:47 PM, Arcaith said: Another alpha related bug; geometry that should be drawn before the water is being drawn after it. That's weird actually, seeing how any group with an alpha value that isn't 255 should be drawn after all opaque ones, otherwise the translucency might not work correctly. I'm also pretty sure I didn't change anything related to that recently. If I could use mesh type 2 the whole thing should/might be less of a problem, but I have no idea how to calculate the clipping coordinates needed for that. As for the other texture alpha channel glitches, I cannot say for sure. This is probably another problem with the rendering order, seeing how again alpha is involved. I'll try to experiment with this and see if I can come up with a concrete diagnosis and cure, so to speak... On 9/20/2011 at 8:41 AM, Okami Amaterasu said: My friend found an odd glitch while testing a map. I think she may have used some incorrect terrain types. Edit: No, I think there may be a bug somewhere. I'll do some more testing. It might actually be a problem with the polygon type, see what the "Terrain Type" and "Environment" options are set to, and try setting them both to 0 if they aren't already. Link to comment Share on other sites More sharing options...
haddockd Posted September 20, 2011 Share Posted September 20, 2011 @ Okami Amaterasu: I am probably way off but looking at it with my untrained eye, it appears to act like fog (pink fog) is present. Link to comment Share on other sites More sharing options...
Okami Amaterasu Posted September 20, 2011 Share Posted September 20, 2011 It's a glitch in the environment/terrain I can probably fix it by making a new scene. There's also a glitch that'll cause something similar in all maps, but I forgot how to do the glitch. Link to comment Share on other sites More sharing options...
spinout Posted September 20, 2011 Share Posted September 20, 2011 On 9/20/2011 at 12:43 PM, xdaniel said: If I could use mesh type 2 the whole thing should/might be less of a problem, but I have no idea how to calculate the clipping coordinates needed for that.Try:clip.min.x = dl_min.x - draw_distance; clip.min.z = dl_min.z - draw_distance; clip.max.x = dl_max.x + draw_distance; clip.max.z = dl_max.z + draw_distance; You could also go around this whole problem by setting the 'far' display list to the same one as the near display list. Link to comment Share on other sites More sharing options...
Okami Amaterasu Posted September 24, 2011 Share Posted September 24, 2011 (edited) Another few suggestions I have is to let you name your collision types so you don't get confused with what is what, and a "reload Scene" button so you don't have to go back and select the scene every time you make a change. Oh, something you may for forgotten or overlooked is a "going down" ladder collision type - so you can get down ladders. Also crawlspace collision types. Edited September 26, 2011 by Okami Amaterasu Link to comment Share on other sites More sharing options...
xdaniel Posted September 28, 2011 Author Share Posted September 28, 2011 Uhm, an update of sorts, I guess - although I mainly want to say I haven't worked on this in a while, got distracted by WW/TP as one can probably see from the WW hacking thread. Do note that I am still reading this thread, have read your suggestions (here and in PMs), but don't yet have anything to say about them. I will keep them in mind, tho. Link to comment Share on other sites More sharing options...
Kargaroc Posted October 3, 2011 Share Posted October 3, 2011 I still don't fully understand how to make transition actors in SharpOcarina... Do I have to have the object loaded for the door model? What are the appropriate values for the Cam, and the number and variable? Why the camera suddenly goes all weird, and doesn't follow link. Link to comment Share on other sites More sharing options...
Okami Amaterasu Posted October 3, 2011 Share Posted October 3, 2011 What are you trying to do? Use a door, or a plane (as in the "Room Changing Black Plane" actor)? Link to comment Share on other sites More sharing options...
Kargaroc Posted October 3, 2011 Share Posted October 3, 2011 On 10/3/2011 at 8:04 PM, Okami Amaterasu said: What are you trying to do? Use a door, or a plane (as in the "Room Changing Black Plane" actor)? A door, preferably one that raises up, but values for a normal door would be helpful aswell if I don't want to post again when I want to make another door. Link to comment Share on other sites More sharing options...
xdaniel Posted October 3, 2011 Author Share Posted October 3, 2011 Although I tend to point to the Z64 Wiki in it, I can't stress it enough that the Readme is there for a reason. Also: http://wiki.spinout1...frastructure.29 Link to comment Share on other sites More sharing options...
Kargaroc Posted October 3, 2011 Share Posted October 3, 2011 On 10/3/2011 at 8:54 PM, xdaniel said: Although I tend to point to the Z64 Wiki in it, I can't stress it enough that the Readme is there for a reason.I read the readme and I didn't find anything that helped me. It was informative though, thanks Link to comment Share on other sites More sharing options...
SanguinettiMods Posted October 3, 2011 Share Posted October 3, 2011 Front Switch: 00 Cam : (Room number, starting at 01) Back Switch: 00 Cam: FF 002E 0001 Metal-studded, lifting wooden door 002E = Actor Number 0001 = Group 0000 = Variable Link to comment Share on other sites More sharing options...
xdaniel Posted October 3, 2011 Author Share Posted October 3, 2011 On 10/3/2011 at 9:13 PM, SanguinettiMods said: Front Switch: 00 Cam : (Room number, starting at 01) Back Switch: 00 Cam: FF Uhm, you switched the options around; the Front/Back Switch options are the room numbers to switch to, depending on the side of the door, Cam is how the camera reacts during the transition (00, 0F, FF being valid, I think?). Link to comment Share on other sites More sharing options...
spinout Posted October 3, 2011 Share Posted October 3, 2011 Yes. http://wiki.spinout182.com/w/Maps_and_Scenes#Transition_Actors Link to comment Share on other sites More sharing options...
Kargaroc Posted October 4, 2011 Share Posted October 4, 2011 okay, I got the door to work, but it doesn't load the next room. And, I still don't like the maximum scale cap of 20, as when I used the old importer, I normally set the scale to around 40 or so. The reason I use the scale, is because with Lightwave, the modeling program I use, it uses meters, not arbitrary units. I make my rooms reasonably large, but not enormous. For instance, the ceiling to a hallway would be 3 meters tall. If I wanted to scale it manually, I would also have to fix all of the texture scale and stuff, which is a pain. Link to comment Share on other sites More sharing options...
Arcaith Posted October 4, 2011 Share Posted October 4, 2011 When you export, does it allow something along the lines of 1 meter = 1 unit? If so, just use the option it allows as your base unit amount, and that should translate fine to a 1:1 import. Link to comment Share on other sites More sharing options...
spinout Posted October 4, 2011 Share Posted October 4, 2011 Kargaroc: What values did you put in for front switch [__] cam [__] back switch [__] cam [__] ? Link to comment Share on other sites More sharing options...
Kargaroc Posted October 4, 2011 Share Posted October 4, 2011 On 10/4/2011 at 2:49 AM, spinout said: Kargaroc: What values did you put in for front switch [__] cam [__] fack switch [__] cam [__] ? I tried 00/00 and 01/FF And about lightwave, I don't think is has that, although I think that 1 meter already does equal one unit. But once again, that would require me to fix all the maps I have already done. Link to comment Share on other sites More sharing options...
SanguinettiMods Posted October 4, 2011 Share Posted October 4, 2011 Try 00/01 00/ FF Link to comment Share on other sites More sharing options...
spinout Posted October 4, 2011 Share Posted October 4, 2011 On 10/4/2011 at 2:57 AM, Kargaroc said: I tried 00/00 and 01/FF And about lightwave, I don't think is has that, although I think that 1 meter already does equal one unit. But once again, that would require me to fix all the maps I have already done. On 10/4/2011 at 3:13 AM, SanguinettiMods said: Try 00/01 00/ FF It should be something likefront switch [00] cam [FF] back switch [01] cam [FF] OR front switch [01] cam [FF] back switch [00] cam [FF] Link to comment Share on other sites More sharing options...
Kargaroc Posted October 4, 2011 Share Posted October 4, 2011 http://dl.dropbox.com/u/16672629/triforce_dungeon.7z here's the map Link to comment Share on other sites More sharing options...
spinout Posted October 4, 2011 Share Posted October 4, 2011 Just tried it using the first values I suggested, worked perfect. You had them all set to 0. Also, you are missing collision for the door - it should be part of the scene obj file. Link to comment Share on other sites More sharing options...
Arcaith Posted October 4, 2011 Share Posted October 4, 2011 Kargaroc, if 1 meter is 1 unit, just scale them in Lightwave instead. Link to comment Share on other sites More sharing options...
SanguinettiMods Posted October 4, 2011 Share Posted October 4, 2011 Front Switch : Room to Switch to when you go through the door. in this case, 01 Back Switch, Room to Switch to when you go through the door from the back, in this case, 00. What I did, I copied the values xdaniel had for his "Test Dungeon" Which was Front Switch: Room to Switch to Cam: 01 BackSwitch: 00 Cam FF for all of them Link to comment Share on other sites More sharing options...
xdaniel Posted October 4, 2011 Author Share Posted October 4, 2011 On 10/4/2011 at 12:45 PM, SanguinettiMods said: What I did, I copied the values xdaniel had for his "Test Dungeon" Which was Front Switch: Room to Switch to Cam: 01 BackSwitch: 00 Cam FF for all of them Sorry, but that can't be. Looking at "Demo Scene.xml", the values are: <FrontSwitchTo>1</FrontSwitchTo> <FrontCamera>255</FrontCamera> <BackSwitchTo>0</BackSwitchTo> <BackCamera>255</BackCamera> <FrontSwitchTo>2</FrontSwitchTo> <FrontCamera>255</FrontCamera> <BackSwitchTo>0</BackSwitchTo> <BackCamera>255</BackCamera> <FrontSwitchTo>3</FrontSwitchTo> <FrontCamera>255</FrontCamera> <BackSwitchTo>0</BackSwitchTo> <BackCamera>255</BackCamera> Link to comment Share on other sites More sharing options...
