I know there are different variables that I can use for Door Actors.., But I don't think this problem can be solved by simply changing the variable used.
There is a difference between doors, for sake of example, in the Deku Tree, and the Spirit Temple.
If I wanted to make the Deku Tree use the Spirit temple doors, what would I have to do?
What I've tried
> Adding the Object (group) of the spirit temple door
SanguinettiModsI know there are different variables that I can use for Door Actors.., But I don't think this problem can be solved by simply changing the variable used.
What I've tried
> Nothing else...
1 answer to this question
