how to run Mupen64Plus
alphaheiti
I'm assuming windows.
Download and extract mupen64plus 1.99.4. Drag and drop mupen64plus-ui-console.exe to the start menu. Then drag and drop any ROM onto the mupen64plus-ui-console executable and it should run. I just tested it with a Debug ROM, it worked right out of the box.
Strange. Try running it from the command line (Start->Run [type] cmd [ENTER] -> [in new window type]cd "C:/path/to/mupen64plus-ui-console.exe" [ENTER] [then type] mupen64plus-ui-console.exe "C:/path/to/rom.z64" [ENTER]
Then, maximize the window and take a screenshot of it, I cannot help you unless I know what is going wrong.
It must be the graphics plugin. I know other ones exist (and have quite good results), but I don't know if they have windows builds available for download.
What specifically do you want M64P for? If you are concerned about having it for the URA Project, now is not the time to worry about that - there is going to be a custom release for the URA Project.
Speaking of this, I wonder if the... Well I guess I will call it the "URA Zelda runner" will be distributed with the final patch?
Surely a separate download will be kept for the source, just in case any showstoppers are found or more accurate ways to emulate things are found.
