SanguinettiMods Posted September 27, 2011 Share Posted September 27, 2011 I've tried porting maps from Majora's Mask to OoT, and most of them work, sort of, but Termina Field crashes when I try to load the area. Help? http://ifile.it/6gvjytf/HALP_Termina.ppf Link to comment Share on other sites More sharing options...
0 spinout Posted September 28, 2011 Share Posted September 28, 2011 Use this kind of patch from now on, please[1]. I'll be glad to help you when I get a moment, though, I probably won't be free for a few hours. A few common things that might screw it up: -Display list jumps [0xDE in display lists] -Multiple headers [0x18 command, replace with 0x01000000 00000000] -Cut scene stuff -MM only header commands [Any header command > 0x19] -Bad collision types [Try setting them all to 00000000 00000000] z64porter does all of this and works 98% of the time, so I suggest you give it a shot. Link to comment Share on other sites More sharing options...
0 SanguinettiMods Posted September 28, 2011 Author Share Posted September 28, 2011 Use this kind of patch from now on, please[1]. Oh, I would, but I tried making a patch, it took a total half hour to make it.... Link to comment Share on other sites More sharing options...
0 spinout Posted September 28, 2011 Share Posted September 28, 2011 Uncheck the delta box. Link to comment Share on other sites More sharing options...
0 SanguinettiMods Posted September 29, 2011 Author Share Posted September 29, 2011 I know Z64 porter can do this, the point is, I want to do it manually. And I can't figure out why it won't work. Link to comment Share on other sites More sharing options...
0 spinout Posted September 29, 2011 Share Posted September 29, 2011 I only said that so you could compare the results. Did you try any of my suggestions? If not, try them all, and send a patch with all the changes (including the ones I suggested) applied. Link to comment Share on other sites More sharing options...
SanguinettiModsI've tried porting maps from Majora's Mask to OoT, and most of them work, sort of, but Termina Field crashes when I try to load the area. Help?
5 answers to this question
