Display List Texture Blocks.
SanguinettiMods
Does anyone have any helpful information on how to calculate the exact texture block of each of the 15 different types of F3DZEX Textures?
I tried ZLE2, but that doesn't work with EVERY texture.
If anyone has any info on how to calculate the -EXACT- Tetxure Data block, instead of guessing for
00: 4-bit RGBA
08: 8-bit RGBA
10: 16-bit RGBA
20: 4-bit YUV (rare)
28: 8-bit YUV (rare)
30: 16-bit YUV (rare)
40: 4-bit CI
48: 8-bit CI
50: 16-bit CI
60: 4-bit IA
68: 8-bit IA
70: 16-bit IA
80: 4-bit I
88: 8-bit I
90: 16-bit I
I'd gladly appreciate it.
1 answer to this question
gDPSetTileSize should have what you're looking for.
In display lists, it is used like this:
gDPSetTileSize(pkt, 0, 0, 0, ((width)-1) << 2, ((height)-1) << 2);
It is defined as so:
#define G_SETTILESIZE 0xf2
#define gDPSetTileSize(pkt, t, uls, ult, lrs, lrt)
gDPLoadTileGeneric(pkt, G_SETTILESIZE, t, uls, ult, lrs, lrt)
#define gsDPLoadTileGeneric(c, tile, uls, ult, lrs, lrt) \
_SHIFTL(c, 24, 8) | _SHIFTL(uls, 12, 12) | _SHIFTL(ult, 0, 12), \
_SHIFTL(tile, 24, 3) | _SHIFTL(lrs, 12, 12) | _SHIFTL(lrt, 0, 12)\
Meaning the width and height can be extracted like so:
width = ( _SHIFTR(w1, 12, 12) >> 2) + 1;
height = ( _SHIFTR(w1, 0, 12) >> 2) + 1;
In simpler terms:
F2000000 00wwwhhh
width = (w / 4) + 1
height = (h / 4) + 1
The size (in bytes) of the texture can be determined by the bits per pixel multiplied by the number of pixels divided by eight:
bytes of pixel data = bpp * width * height / 8
