Importing zobj files into utility of time
Robin Guy
11 answers to this question
You'll need to use Zelda Resource Extractor (ZRE). It's a fairly simple tool which mainly runs with arguments but can be run without them (i.e. just double-clicking the application) if you don't know how create batch files or run programs from command line. The program will ask you where your ROM is and then dump out the contents of it in a subfolder of wherever ZRE is--don't worry if it says the file size is abnormal, it will still work. If by some egregious turn of events no one beats me to the punch, I'll upload the program for you to use when I get home in about 7 hours.
For a reference, if you're just trying to load up models or change actors, you would probably be much better off using either the newest Utility of Time or xdaniel's SayakaGL. These read directly from the ROM and do not require files to be extracted (though UoT still supports loading individual files).
